Xperia ZL 4.2.2: Walkman controls and lock screen conflict
ylapas
Anyone is facing the problem of blinkink album art and Walkman controls while playing music on lock screen widgets? I looks as app conflict here because Walkman is trying to go on top of of clock widget and is rapidly blinking. Screenshot does not capture this, yet you can see to screens on top of each other and Walkman is the blinking one and is not the "winner" of lock screens battle Smiling_Face_with_open_mouth_&_closed_EyesScreenshot_2013-06-27-16-39-00.jpg
24 REPLIES 24
murzamuammar
Are smart key make a error in lockscreen, smart key app must be solve
eutactic
oh yes, smartkey is the reason.
no need to uninstall, just disabled all actions of smartkey also can fix the problem.
Deeply thx. ~~
Jaswanth
Thanks a lot.After uninstaling smart key app,walkman works great in lockscreen!
KaizaValancer
Don't have to uninstall smart key, just disable music controls in.smart key and problem solved:)
jhometal
many thx!
i was trying to solve this issue too!
