Xperia ZL body hot
9W2ERV
Xperia ZL body hot
Hi frenz, got a prob w my ZL. Body become hot when I play games and during charging.... Plz help.
shihstouch
Enthusiast
Make sure to close all BG apps...
Go to Settings > Apps > Running ( and check if any third party apps are running, Stop it )
Also for testing your device you can boot in safe mode and check charging...
To enable safe mode
  1. Turn off the device.
  2. Press and hold down the power key Power key of Sony Smartphone until the phone vibrates.
  3. Wait until the Xperia™ logotype disappears.
  4. Press and hold the volume down key. The device then restarts in safe mode.
Note: To exit safe mode, restart the device.
3 REPLIES 3
shihstouch
Enthusiast
While playing games its normal, long time gaming will leads to excess heat...
Heat while charging needs to be considered, please check any background apps are running...
9W2ERV
Ok, but how to check any running background apps ?
shihstouch
Enthusiast
To enable safe mode
