Xperia ZQ - Message
WIL
Xperia ZQ - Message
again, I havent found xperia zq issue ....
I have been trying to send messages from the contacts, but after I choose anyone, an error occurs saying that there are invalid chars, however, if I change it to only numbers, it works. the question is, if I want to choose anyone from the contact list, how can I do it? the software should put it correctly? is it a bug? or is there a way to setup it to accept only numbers from the contact list? tks.
Uliwooly
start typing the name and you will get a drop down menu with the list of contacts > tap on one of the contact > done
6 REPLIES 6
Uliwooly
WIL
Hi uliwooly, it worked, tks, but why it doesnt work if I choose from the contact list? is it a bug? tks
Uliwooly
could you elaborate on "contact list"? are you talking about the phonebook?
just look for the contact > tap on the messaging icon > voila done
WIL
yes, it is phonebook, but anyone that I choose, the message saying that it is invalid occurs
Uliwooly
do you have different messaging apps? that might be the issue here
WIL
to send sms, mms....NO....I am using the message application that was installed....
