Xperia ZR Battery Life
gabrielabatista
two days ago my battery ZR is consuming me between 50 and 85% in media server and do not understand why?
when I check the battery usage :
-media server used 50% (sometimes 85%)
-screen 25%
- cell standby 11%
-Android system 8%,
- phone idle 8%
- wifi 6%,
- os 4%
-voice calls 3%
-Clean master 3%
-phone 2%
normally the screen was the highest value and for some reason the media server up a lot
When I click on the media server, I can see the percentage used and below says: "battery used by the application" but I don´t know to which application refers to deactivate it. I can not find what the problem is but that is consuming a lot of battery. Help me please!
Sam
Legend
Legend
That is odd, however have you tried simply performing a restart of the phone followed by a full charge to see if the problem continues?
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
4 REPLIES 4
Sam
Legend
Legend
gabrielabatista
I'll try ... thank you very much.
gabrielabatista
but what is the media server, what works, is an application or is activated when an application is installed?
KJ_Yap
I had a same problem with my xperia zl too. I guess whenever there is a sound out from the speaker, then the media server will run. So I kept all my sound turned off eg. Touch sounds, screen lock sound, dial pad tone. I also rarely listen to music and the worst is i turn off the gameplay sound while I'm playing game. These decreased my media server usage.
