Hi lawrence8891,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
I can clarify that this symbol is the NFC symbol. Simply turn off NFC and the icon will be removed.
I hope this helps.
Hello does anybody know what the "Z" icon is at the top of the screen?
Thanks
Hi lawrence8891,
I hope this helps.
