z1 overheats
kph100
z1 overheats
Hi has anyone been affected by this illness on their phone, I thought it was the sd card that was filled to the brim so i stupidly went and got a new one,still got the same problem overheats in the top left corner of phone. When this happens my music library disappears, no pictures, no camera and a very hot phone is anyone else suffering this infliction? And does anyone have the cure/medical advice on how to fix this. Many thanks
Tags (1)
profile.country.RO.title
_alexdon_
You are welcome.
alexdon
27 REPLIES 27
_alexdon_
Take the phone to a sony service.It is normal to overheat when used intensely,but if it makes your things dissapear,it could be bad.
alexdon
kph100
I will keep that in mind. Thanks
_alexdon_
You are welcome.
alexdon
Sam
Legend
Legend
The phone getting hot is normal but it should be getting to the point where it malfunctions. If this continues it would be worth returning it so that it may be assessed by an authorised agent.
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
kph100
Do i take it back to where i purchased it or send it to sony?
Sam
Legend
Legend
I would advise contacting your local Xperia Care team to clarify the local process for this.
kph100
I think i found out why z1 overheats, if you download films it stores it in the phones memory rather than the sd card?(i had to delete films) Shorly thats a bit of a design flaw by Sony?
_alexdon_
This should not be an excessive heat issue.
alexdon
kph100
Is there another way to use the sd card rather than the onboard storage, for me it looks like this is an ongoing problem with Sony phones, it happened with my arc s as well (overheats had to delete apps films and so on)
