Z3 mic not working while talking on speaker
sid3091
Ive just noticed this issue on my month old z3. People can hear me fine if i talk using the earpiece, but the moment i switch to speaker, my voice sounds distant, or I cant be heard at all. Ive tried factory reset, but no luck.
50 REPLIES 50
profile.country.US.title
Qatrium
You hace an app blocking the Mic while calling, it can be any audio recording app, and sometimes it's caused by OK Google detection from any screen. Try to disable either of them and check again.
KazIRahman
I am using 5.1.1
When i put on the speaker and revert back to headset earpiece this problem occurs.
xavinux
Enthusiast
Hi @KazIRahman
I suggest to boot your device in safe mode and check if the issue persists:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
I hope can be useful and I'm at disposal for any question.
Best Regards,
KazIRahman
Guys problem is solved it was for the call recording app..thanks everyone for helping
Peter_D123
I had the problem that the mic in my headset did not work all of a sudden during a call.
When i turned on the speaker, then turned it off again, the mic worked and the person on the other end could hear me again.
As suggested by other ppl here, i turned off google now "OK Google detection from any screen", and voila the mic worked as supposed to again.
So for me it was that ok google detection blocked the mic some how.
I could also point out that i use googles own launcher not the sony one.
/P
emk
Settings > security > smart lock > trusted voice > off
Julhasfi
Same here after updating to 5.1.1. any solution?
xavinux
Enthusiast
Hi @Julhasfi
This problem is caused by some applications that are installed. You could try to turned off google now "OK Google detection from any screen" or could be for the call recording app as another users report.
If this issue persists, reboot your device in safe mode to see if the problem disappear:
Best Regards,
Mohit1398
Whenever I Call A Person I Can Connect To Them And Hear Their Voice Too But They Can't Hear My Voice (Not Connected To Headset) Untill I Turn To Loudspeaker
And At The Time Of Receiving Call I Don't Have Any Problem.. When Restart My Device Every Thing Will Be Normal Then Again The Same Problem
Please Help, My Device Is Not Even A Year Older
Tags (1)
Qatrium
Some app might be interfering with your mic during calls, it can be a call recorder app mostly. Sometimes it's caused when you enable "OK Google" detection from any screen.
