I have seen this discussed elsewhere. My Z5 compact rarely shows five bars for my Fido LTE network. It's usually around 1. Yet... as mentioned elsewhere, my mobile data speed is OK, not great, but it's working. However, in battery settings, it shows that I've had a poor mobile network connection all throughout the day... and I do have a fairly high Cell Standby battery usage.
Is this a phone problem? My previous Galaxy Note 3 showed a good healthy Fido LTE mobile data connection at work. Sitting at same desk with my Z5 Compact, it shows that I have one bar, throughout most of Vancouver, it shows me as always having one bar. I get full bars at the strangest of locations: in a Skytrain (subway) station for example.
Is there something poor or wrong with the mobile network antenna for this phone? Thank you.
Thanks, I just checked mine, it's between -117 and -110 which is horrible all around.
That's indeed poor network coverage, that will have to be addressed by your carrier.
youll find that sony shows the coverage reception bars (at the top) much lower than other phone manufacturers. ive checked my other phones, motorola and samsung and they will usually show 2-3 bars even though the db is the same on all the phones (around 100db).
i read in one of the other post somewhere, that its how sony shows the reception on the lte signal. weird..but as long as its not dropping like than its ok..annoying but ok.
im in the same boat as you.
I just want to report i have the same poor network coverage. 0 to 2 or 3 while living in a big city using the best provider..
I contstantly have network losses when i'm on the phone calling with someone. Like 4 seconds people can not hear me anymore.
I tested with oter simcards and changed my simcard to an iphone or samsung, having great network coverage.
My conclusion is that the antenna is very bad, and while i also have the the connection loss when calling someone, i think i a have a very bad one....
I'm really interested if more people have this signal loss while phoning?
For me, this is not acceptable, i call allot during the day..
Hopefully there will be a fix, or i'll have to switch t another phone.
Same problem here. I have factory reset the phone completely and reinserted sim. No luck.
My wifes iphone on the same network has great reception.
I am pleased with the speed and photo quality but I generally disspointed with my Z5 compact.
Signal quality.
Speed to open camera and take a photo is slow too.
I going for industry standard S8 for my next phone.
