My auto rotate no longer wants to work.
I have updated all applications and systems, turned my phone off and restarted it and still it doesn't want to work.
Is there anything that can be done to fix it?
try to run your device on safe mode
make sure that the auto rotate setting is toggled in the quick settings bar
try to perform software repair using Xperia Companion
