Hi all,
unfortunately Saturday i have broken my phone. The screen is not usable anymore.
Unfortunately i do not have the USB debugging option enabled...
What can i do to backup my data or to use NFC to move the data and the app to my new phone (always an Xperia)....
OTG is the only solution available for me?
Thanks!
Nadia
Hi.
Sorry to know that 😕
Did you try connect to Xperia Companion?
With the phone off, pressing the power button and volume down, i believe. The same procedure you would do to update or repair the phone.
