There is a white dot located at the lower left of my screen. I didnt notice this before the update of 6.0.1, this is visible only when the screen is white and bright. What cause this problem? I didnt drop this, it just came out of nowhere (like RKO out of nowhere). See at the Mic icon.
I can't see the picture just yet, if it's a bright dot then that's a stuck pixel, if it's a black dot that's a dead pixel, if it seems like a stain that could be due to stress in that area.
Please Make the Display test to see, if this is indeed a Hardware issue.
Settings-->About--->Diagnose--->Test--->Display--->Display
Hello!
I see, this thread is almost one year old, but... A few days ago, exactly the same issue occured to me at exactly the same spot...
I would kindly like to ask you, how did it go with your phone?
Best regards,
Roman
I had and have the same problem. My dispaly was changed and after sometime have similar issues. No I'm changing the Z5 into Huawei Mate 9 pro (after last Android updates) so will sent this for repairing again.
@sangod wrote:I had and have the same problem. My dispaly was changed and after sometime have similar issues. No I'm changing the Z5 into Huawei Mate 9 pro (after last Android updates) so will sent this for repairing again.
Thanks for your answer.
So you suggest, that it is no use getting it changed? Also... Have you experienced any worsening of this situation?
Thanks in advance,
Roman
I do not know. After the dispaly was changed everything was ok. Now it happen again. I do not see that there is more such white places, anyhow I will send it to the service.
@sangod wrote:I do not know. After the dispaly was changed everything was ok. Now it happen again. I do not see that there is more such white places, anyhow I will send it to the service.
Thanks. I mean, it is barely visible, however, who would expect anything like this on such a premium device??? So I see, the only solution for me is to send it to the authorized service. Maaan, since they do not give you any spare phone...
Nevermind, thanks for your answers and help.
Roman
With my z5 there was/is much more than one. It starts from one place.
