Sony Pictures Core doesn’t load on my XR-65X93J
profile.country.BG.title
Snuupy23
Hey guys,
When I bought the TV I was using Sony Core, now I saw that it’s updated to Sony Pictures Core.
However, I can see only what I watched. I can’t search, I cannot access IMAX ENHANCED movies, it doesn’t load at all. There is no error message or something else.
I’ve tried to delete cache/cookies/disable app - nothing was improved.
Please help.
7 REPLIES 7
SatoruGojo
Hey @Snuupy23, Can you try to update the TV SW v6.7480, try to update the app itself.
Force stop the app: Go to Home →Settings→Apps→Select the app →Clear data →Clear Cache→Force stop,  and test it again.
Snuupy23
Hey @SatoruGojo ,
I've done this couple of times + hard reset the TV and update the app again. The TV is with the latest software.
TheMaze
Hey @Snuupy23
I'd recommend that you try performing a factory data reset: https://www.sony.co.uk/electronics/support/articles/00274122
Snuupy23
I’ve done this already.
SatoruGojo
Hey @Snuupy23, Do you have the same issue with any other app, or it's just the Sony Pictures Core? Is it a permanent issue or intermittent?
Snuupy23
No, only this one.
also, there was an article that it will be an PS5 app, but I don’t have it in the playstation store.
However, I want the app working on my TV.
SatoruGojo
You can try different source for the internet such as hotspot and test it if it didn't work still I would say that you should contact the support team for that.
@Snuupy23
