Build Quality Poor (NWZ-A845)
profile.country.en_GB.title
santacrunch
Is it typical of this model?
The "glass" front does not fit flush with the case on the right-hand side. The gap is about the thickness of a fingernail.
The buttons are wobbly and lower profile than they should be because of this looseness.
The glass front is also higher than the aluminium front is (where the buttons are) creating a lip.
The front control area also has a gap between it and the case back.
I am amazed at this product from Sony. A fairly high-end model with very average sound quality, excessive zealotry when it comes to EU regs and slap-dash construction.
And I can't return it for a refund!
1 REPLY 1
Dreamnine
If yours has poor build quality you should return it.
Message was edited by: Dreamnine
