ds2mph
Camera angle
Sony mobile china says that 26mm lens have 75° angle, 52mm lens have 45° angle, and 16mm lens have 130° angle
Sony mobile Hong Kong says that 26mm lens have 78° angle, 52mm lens have 46° angle, and 16mm lens have 130° angle
Which one is correct?
Martin1
Enthusiast
Hi @ds2mph, let me see if I can answer your question.
The Xperia 1 triple lens main camera has the following focal lengths and angles of view:
16mm130°
26mm78°
52mm45°
So in this case, both Sony Mobile China and Sony Mobile Hong Kong is right in some places and wrong in other places. Please note though that the effective angle of view when photographing is to a large extent affected by factors such as aspect ratio and lens correction. For example, a 130° angle of view (measured diagonally in the frame) using the 16mm lens requires a 4:3 aspect ratio without lens correction.
I hope that helped! Have a nice day! Slightly_smiling_Face
1 REPLY 1
Martin1
Enthusiast
16mm130°
26mm78°
52mm45°
