Browse whilst in conversation
Hi.
Can someone help? I'm unable to browse (use data) whilst in conversation. Is there a setting somewhere to fix this?
4 REPLIES 4
profile.country.PH.title
MarlonUk1
hello @ungkarathotmail.com
do you mean while you are in a call? if you have side sense activated, you can tap on the side to open 2:1 multi window. depending on the app you are using you can open 2 apps at the same time...
settings>display>advance>side sense,
CosmicTomato
Specialist
Hello there, I believe if you're on a normal phone call through the SIM, you'd only be able to browse using WiFi.
RottenFoxBreath
Enthusiast
Not like that on the Xperia 1 II.
I Im on a call to say my daughter, I can easily browse, and look at something shes mentioned online, using data at the same time.
This isn't the 90's you know! 😀
CosmicTomato
Specialist
You could be right, but I don't know what device they have, it's just this wasn't an option in a lot of phones I owned.
If that's the case though, they may need to check your network mode in settings.
