Using v2.00 firmware.
If l set the resolution to 21MB (APS-C cropped) and save it to Camera set.memory if changes to 50MB (FULL FRAME) on recall.
And if l set the camera to 21MB crop and switch the camera off and on it goes to 50MB full, a bit frustrating.
I don't think it did this with the old firmware.
Try to reset & initialize the camera then and if you have another memory card you can test it as well. @GordonT
Hey @GordonT
You can try updating to v. 2.01 and check if it fixes this issue. It has been just released, a few days ago.
https://www.sony.co.uk/electronics/support/e-mount-body-ilce-1-series/ilce-1
Using v2.01, no change
Do you have an A1 to try it on ?
Here's the sequence, showing saving at 21MB, recalling at 50MB...
Hey @GordonT
Are you using a compatible memory card from here?
https://support.d-imaging.sony.co.jp/www/cscs/accessories/?mdl=ILCE-1&area=gwt&lang=en_GB
Yes
CEA-G80T
I tried a Sony tough 32gb sd card, no change.
Did a reset and initialise with the CEA-G80T inserted and success !!
let's see if it fixes anything else !
Thankyou very much.
sometimes seem to work as an old PC with windows 8.0 e🙄
