Hello, I recently bought an a7rv camera with which I am very satisfied with one small exception. It does not fit well with the 200-600 G lens. 90% misses the focus. With the 24-70 f2.8 lens it works flawlessly. Do you think an a7iv would do better with 200-600? Thank you!
On the advice of a friend I reset the camera with the lens attached. Now it works very well. The problem has been solved.
I also updated to SEl200600 the latest firmware version and still in vain. It worked fine with my old a7iii. Thanks for the answer, but unfortunately with Sony Romania it is more difficult
Have you also tried resetting the Camera? Could it be a Settings problem?
I also reset the camera. Someone told me that because of the large number of pixels it would work like this and advised me to try an a7iv
🤔 mmm...
Min 5:38:
Thank you for the answers. I will also try to use a tripod.
