Alpha 1 and A6700 deleting group when first image protected
GordonT
If l set the cameras to group photos and take a burst of images, then protect the first image they won't let me delete the group. If l protect any other image in the group, and not the first, they will let me delete the group.
Seems strange feature, which l note the A9iii doesn't do, it lets you protect the first and delete the group.
It would be nice to get this 'fixed' in the Software updates.
8 REPLIES 8
GordonT
Appears to be fixed with A1 update v2.00 !! Thanks to Sony.
GordonT
Just update A6700 to v1.3 but unfortunately the 'issue' isn't fixed.
Anonymous
Not applicable
Hey @GordonT
I think it's more logical for the firmware that it doesn't allow deleting a group that has a protected photo at all, whether it's the first one or not
GordonT
That's not the way l use it. I take a burst of images at 20 or 30fps, then find the best individual frames,  protect them and then delete the rest of the group. Works well for me.
Anonymous
Not applicable
Hey @GordonT, you can try taking the batteries out for a min and then reinsert them.
Try to initialize the camera as well: Reset
GordonT
Can l ask what this will achieve ? Is it related to the A1, which is working perfectly for what l need, or the A6700 ?
Anonymous
Not applicable
Hi @GordonT, it's for the ILCE-6700
GordonT
Thankyou. Tried removing the battery, and reinserted, it made no difference to the 'issue'
