1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
Surround with HDMI/ARC is back on live tv!! USB playback suing "Video" app also works with 5.1 using ARC.
But Netflix only supports stereo - yet. Maybe the app itself needs an update
Well, lets hope it gets better!
Hi sdroid, do you have a link to it please?
Guys,
It must have to do something with our caching server. I was not made aware of any other reasons/issues with the update.
Nico
Not being a Netflix/online video consumer ( I have about 20 films recorded off air that I have not had time to watch)audio issues are not a major issue to me but the fact is it should work and should have worked from day one.
What I do not find acceptable is no functional EPG, how do I know when I need to set time aside if have no idea what is on when. It is ridiculous that I have to revert to reinstalling a 7 year old Freeview receiver to get one.
Incidentally this is the response I got from Sony when I raised a number of issues, note the name of the respondant:
In regards to your enquiry, please note that you may get back to the point of sales as it seems that you were misinformed about what the TV can do and you were not advised that some ports would not be accessible if the TV is wall mounted.
Should you have any further questions, please feel free to reply to this email.
Thank you for your enquiry.
Yours sincerely, Mostafa
Sony customer support
Sony Europe Limited
What makes this worse was the fact that although purchased from Currys it was on the recommendation of a Sony representative working in the store on the day I visited.
Methinks Sony customer service staff need a little training as to what the term means, this respodant in particular.
