2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
Triswillmott
@johndstephen83 how did you go about returning it all to Currys? I bought my x8509c and HR-ct780 from Currys about 7 weeks ago and really want rid of them because the list of bugs is getting out of hand now.
Tris Willmott
haberdavid
Maybe someone will upload here all his menu settings on the tv.
i am still having a little lags even when watching regular tv.
i think it something that could be better in the setting menu.
blytant
I'm still having the HDMI lip sync issue. I'm assuming this is going to be fixed on the 28th instead?
alfonzobonzo
KDL-43W756C
something ive noticed since the firmware upgrade,
Before (on the origional firmware) I could change the TV display to 3D mode (2 or 3 different settings IIRC using the sideview app remote)
Now when I try to do the same, it tells me that its unavailiable.
Dont think 3D was a advertised feature of this model so cant really complain.
UKPiglet
@Anonymous
"Lip sync issues - what devices or apps etc?"
Netflix, using default settings and TV speakers on KD55X9305:
1) Sound continuing but stuck picture showing buffering 97% (not seen for a day or two)
2) Inconsistent lip sync. Sometimes it is close. Other times sound is significantly behind picture.
These issues not seen on the same program on other brand of TV or when watching on PC - when moving from one to the other to do comparisons
I've gone to stand by, turned off at wall and restarted several times after upgrade.  When you ask about "reset" do you mean that you recommend a full factory reset? Please can you be specific about the recommendation?
Heckie
Got a weird problem. I have a 50W809C, and a Sony STR-DH550 Receiver plugged into HDMI 4/ARC.
Every time I switch the TV on, the receiver starts, but I get a message saying "If no sound please connect to HDMI 4", and when I check the Bravia Sync settings, it shows it as being connected to HDMI 1/MHL!!
To get it to work I need to unplug the HDMI from the back of receiver and plug it back in.
Anyone else experienceing this? Cant work out if it is a faulty connection on the receiver, but the fact it switches on and I can control the volume using the TV remote suggests that the socket it fine.
Still cant connect to 90% of the Android models, using TV Sideview, including my own set,  since the 5.1.1 update..
TV Sideview: cant find the tv
Google Android TV Remote: Can find the tv, but cant connect to it
Not that I use that function, but I know alot do, including many of our customers. So its more like a "heads up" for any Sony member reading this tread.
gunit1978
Just seen there is an update on the 43inch for the google cast receiver, will update later and let you all know if it works.
Anonymous
Not applicable
@NicolaiLarsen91 - can you confirm if the following works, as one of our forum experts said it worked for him ( @pa3eia )
If you have factory reset the tvs, you must delete the tv in the SideView app and then pair it up again on the tv.
MikeLothian
Casting is working here again
