2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
wills_b
@joquinn27
Youll probably get differing opinions on that.
To be fair, 4K demo reels in bright colours on YouTube look great. That's the highlight of this TV.
Blu Ray picture quality is good, but the contrast is disappointing and there's a lot of reflection on the screen in certain circumstances in dark scenes which is really disappointing. This is using the "cinema pro" setting.
The interface is clunky and slow, all the missing features are a huge issue and I was watching a Blu Ray last night and had to turn off the TV half way through as the pic and sound had gone out of sync.
Shalendran
@TrevorCStevens
I have a Denon AVR connected to Bose speakers. The audio system is in standby when the TV is switched on from standby. I did not have this problem with my previous Sony TV. it used to switch on and off immediately along with the TV.
haberdavid
Hi
I need your help please.
When i am playing movies using Plex app or hdd connected to usb with kodi, i see that the picture is not smooth, the picture shakes on fast moves.any idea ???
haribo411
How do you get Kodi to see your HDD?
Risc0n
Contributor
Guys, is there a way to force the TV to only see 5ghz networks? Currently I have had to separate the networks on my Apple Time Capsule otherwise it won't connect to 5ghz. The only time I can see this is when wifi direct is on which allows auto 2.4 or auto 5ghz, but this kills my internet! The ethernet is only 100mb whereas the wifi is gigabit so obviously i want to use wireless.
This causes issues with my iPad Air 2 and iPhone 6s which both want to connect to 2.4ghz as priority rather than before where it would dynamically select the best signal...
Shalendran
@haribo411
Open kodi, click on add videos, click on Browse. Select the folder on the HDD or network drive. Then you can play all files on the folder or the selected video.
cswalmsley
Picked mine up yesterday 49" X8309C along with the HT-CT780 Sound bar.
not noticed any lip sync issues, however the HDMI ARC between TV and Soundbar does not work correctly. I can get it working by using optical cable but it's frustrating how I get no sound through using HDMI.
The HDMI allows me to change volume up and down on sound bar with TV remote, just no sound. As soon as I switch sound bar off, tv speakers activate.
tried other High speed HDMI cables and had no joy. Tempted to call curry sauce tomorrow and see if an exchange will sort issue out.
Anonymous
Not applicable
andrewsoong
In 99.9% of cases ethernet will be faster than wifi. Even on an 100Mb nic.
Even if these Sony TVs had AC wireless cards, which I doubt, ethernet would be faster in most cases.
Rustyk1
@cswalmsley
I had a very siumilar problem with the same TV and same sound bar.
With me the setup I have is Virgin + Xbox + Aux -> HDMI Switch -> TV -> Sound Bar (ARC).
While it seemed initially to work, once all set up I had similar problems.
The issue was the Virgin box. As far as I could tell it just blasts ARC-style commands down the HDMI cables and generally messes everything up. I resolve it by:
- Check soundbar has ARC enabled in settings
- Turn everything off at the wall
- Disconnect all HDMI cables
- Connect TV to Soundbar on HDMI 3 (ARC)
- Turn on TV
- Turn on soundbar
- These should now work (if not it's a different problem)
- Plug in other cables
- Turn other devices back on
- Everything should now works
I hope that helps. Like I said the problem was very frustrating and yours sounds similar so I'd give this a go before braving Currys customer services!
