2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
rab1973
Not on the 55 they ain't !!!!!!!
Anonymous
Not applicable
There are many models of a 55" tv.  Depends on the series.  See the chart below.
undefined
frogger38
@Anonymous I think a YouView issue but when using the Discover , YouView Films, the Channel 5 films mostly have a year date substituted for the title. As this shows, I don't know how to report this.
undefined
Product is is Sony 2015 KDL 43W805C Android TV, UK Model with YouView, purchased Sept 2015.
Anonymous
Not applicable
@frogger38 - Lol. OK.
Im not too sure either.  Leave it with me and ill see where to take it.  Is this a common thing?
Discover - didnt know anyone used it.
mk1.golf.1983
I too noticed that with the discover button and youview but disabled youview on day of release because it was....
wills_b
I bought my Sony 49x8305c on launch day (I was perplexed at the time at the lack of fanfare), I started posting on this thread on page 7, and I have now returned the TV.
Currys didn't fight it too much, I suspect Sony are quietly accepting the sets back in order not to infuriate the people selling their sets for them.
It's a real shame, was my first Sony TV, I had very high hopes, and it will be my last. The android system is half baked, the set is clearly underpowered, and the actual panel on the 49inch isn't great. The contrast ratio is terrible.
i wish all the best to those people who have kept hold of them. Those considering buying I would advise not to. I'm much happier with the Samsung I now own.
Kevwoods12
I've just checked the uk website and the 55" 850 series Do have different refresh rates.
The 5 is 800hz, the 7 900hz and the 9 is 1000hz, so who are we to believe?
Anonymous
Not applicable
@Kevwoods12 - you are quite correct on the specifications on the website, it does say 800/900/1000
Edit:
I have just looked at another more detailed comparision table, you are correct - my appologies.  The motionflow rate is different to the 5/7/9.  Previous years it has been the stand/tv frame colour that was the only difference between the end digit for the EU market.  I guess this has changed a bit.
frogger38
@Anonymous
It only affects the YouView discover mode, for channel 5 films, then it seems most are affected. One or two get the correct title. If you locate the film in the 5 on demand player, it has the correct title. It has been like this since the launch of YouView.
Pas for the use of the discover function... Someone has to test the software, as the suppliers seem not to. :slight_smile:
@Btw.. My @mention alerts have started working, with minimum delays.
MonkeyWallace
@wills_b how long between buying the TV and getting Curry's to take it back? They've declined to rake mine backas it's been 4 months so I'd be interested in a precedent... Sent from Outlook Mail for Windows 10 phone
