2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
rab1973
Funny, you told me it was the stand colour.
@MonkeyWallace wrote:
@wills_b how long between buying the TV and getting Curry's to take it back? They've declined to rake mine backas it's been 4 months so I'd be interested in a precedent... Sent from Outlook Mail for Windows 10 phone
(Not wills_b but...) Bought ours mid august and took it back Friday (2 days ago). Since it was bought before Sony announced that you couldn't have both YouView and HDD recording, I did what others before me have done and emailed PCW customer support directly to say something like:
At the time of purchase the TV was sold/advertised as being able to do both YV and HDD (when the updates arrived). Since the YouView update arrived it had become apparent it could do one or the other, but not both, and so the TV was not as advertised and under SOG 1979 I wanted to return the TV for a full refund.
It took about 48hours after sending the initial email, and had to supply some additional details (branch number, invoice number etc) before PCW gave me a reference number authorising the return of the TV. There was a little bit of extra faffing in store as they had to ring whoever authorised it to send them something for their system, but it was reasonably straightforward.
The chap in store who did the refund read the internal notes attached to the reference number essentially confimed that PCW had carried out checks and had accepted my claim about dates and advertised features as being correct.
Address I used was: SCCCustomerSolutionsTeam@knowhow.com
I guess if you are genuinely returning the TV based on advertised vs delivered features (assuming you bought it before it all changed), it should be hard for PCW to say no to a return?
Good luck
Folkfanger
@Anonymous I also have the year date rather than titles.
Folkfanger
@royabrown I referred to Sony having licencing issues not Youview. Reading various comments throughout this thread it is clear that no one really knows why a number of thing do not work as it is believed they should and the jury is out until proof is given as to whether there are hardware, software, or licencing issues.
Folkfanger
@Kevwoods12 royabrown is exactly right about the last digit being colour of atand and stand post.
Just read quinnicus' reply. Not so sure now.
Folkfanger
@Anonymous That's interesting. I checked the full specs on the Sony website before buying a month ago and the only difference between lat digits on the 85 series was stand and post colour.
Kevwoods12
 I bought mine in August and knew about the Motionflow differences then,  it's the reason I got the 8509, they were all the same price.
Inha1966
I just received an e-mail from Sony telling me to "Enhance my TV expeince" by susgesting a number of acessories. One of these accesories is the Sony BR200 Skype Camera.
Astonishing recommendation given that the only TV I have registered with them is a Sony Bravia "Smart" Android TV, which is not compatible with Skype. Do their various departments even understand what their Android TVs are capable of (or not)?
I had already bought the expensive Sony BR200 camera with the TV and had to return it. Should have returned the TV as well!
I think this is false advertising! How can I belive that any of their other recommended accesories is compatible?
Kevwoods12
So if the 85 series do have the same Motionflow abilities, it's another example of false advertising imo.
frankie1g
How can you say the say is good are you being sarcastic? You seem to list some fundamental faults  Sent from my Samsung device
