2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
Kevwoods12
Eh?
SDCEGavster
@Kevwoods12 wrote:
 I bought mine in August and knew about the Motionflow differences then,  it's the reason I got the 8509, they were all the same price.
I spoke to the 'Sony' Salesman in John Lewis about this. After checking the specs on the Sony website and quoting them to him, he replied, "No, it's a mistake, all the refresh rates are the same on all models."
I have a KDL55X8507 and only difference between mine and an 8509 is the stand and frame colour it seems.
andipr
SDCEGavster -
I have the KD43X8309CBU and went for this over the 5 or 7 models due to the Hz rates.
Looking on the Sony site and it still states different rates for the 5/7/9 models:
http://www.sony.co.uk/electronics/televisions/x8300c-series/specifications
Not sure what's going on here anymore, but if they are all the same rate I'll be happy as long as it's 1000Hz and not lower.
My Model KD43X8309CBU
SDCEGavster
@andipr wrote:
@SDCEGavster -
The specs are still the same online for the KDL55X series TVs. It's just not true apparently.
I believe they are 900Hz, but you will not be able to tell the difference between 900Hz and 1000Hz anyway.
cozzykim
The 2nd digit of the last four is the 'Motionflow' refresh rate.
These refresh rate specs are 'emperor's new clothes' anyway.
AFAIK they're interpolated, not true refresh rates.
See here:
http://www.rtings.com/tv/learn/fake-refresh-rates-samsung-clear-motion-rate-vs-sony-motionflow-vs-lg...
rab1973
So what is the motion flow rate ? 800-900 or 1000 ???
cozzykim
@rab1973
Sorry, having a senility moment and was relying on memory, it's the 4th digit.
8505 - 800Hz
8507 - 900Hz
8509 - 1000Hz
http://www.sony.co.uk/electronics/televisions/x8500c-series/specifications
SDCEGavster
@cozzykim wrote:
@rab1973
8505 - 800Hz
8507 - 900Hz
8509 - 1000Hz
That's what the Sony site says, but it's not true â€“ according to an actual human being, purportedly working on Sony's behalf at John Lewis.
gandawall
So many people seem to be having problems with their not very smart TVs that there must be something fundamentally wrong at Sony. I have only had my KD43X8309 since 28th Sept. and it has been nothing but trouble. Every few days it completely freezes, sometimes part way through a programme on catch up, and I have found that the only way to fix it is to switch off at the plug and then let it reboot - not what you want when you are trying to enjoy a programme! It is interesting that the delay in acquiring YouView was blamed on 'technical issues'. It's a pity that Sony did not resolve those issues before inflicting this mess on us. And will we ever get a full YouView service? Currently, on my TV, ITVPlayer does not work and it would appear that we are not to get the ability to pause and wind back live TV. Recording to a separate hard drive is promised before Christmas, but can we depend on that being delivered?
Buying a new TV should be an exciting experience, not a pain. I am spending so much time either fixing problems or trying to find out how to fix them that I am seriously thinking of taking it back to Currys for a refund, on the basis that it is not fit for purpose, and buying a Samsung or Panasonic instead.
Anonymous
Not applicable
Hi all
In regards to MotionFlow on certain variations of TVs, ive asked Sony for confirmation on what is correct.  Will post back when i recieve an answer and hopefully put this topic to bed.
