2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
adyjay33
Well I'm glad to see others have the UHD problem too.
I stupidly updated mine to see if it would improve....of course it has not but it seems to have broken the Amazon App now... It worked before the update so I can't see any other reason why it does not now.
Thanks Sony.
KD-55X8509C LATEST FIRMWARE
NOT A HAPPY CUSTOMER!
Kevwoods12
Just downloaded some sample hdr clips,  exodus,  life of pi and a couple of others. Copied onto USB drive and the TV shows video app won't see any files. They are on there. It's not that simple on this telly, is it?
mk1.golf.1983
Download an app for the tv called es file explorer, that find them and is better than the preinstalled apps.
Mekerz
Try putting the files into a folder on the USB drive. The PS4 media player won't show any content that's on the root of a USB stick so maybe Sony televisions are the same.
Kevwoods12
I've got that, no joy there either. It may have been the file type,  it was some osx journalled or summat. I've reformatted it to exFat and copied them again. I'll see how that goes.
profile.country.IE.title
EggDublin
Amazon UHD gone for me also. Same error.
lgcebr
I have the same Amazon UHD problem with the same error message.  I have logged the issue with Amazon although the December 10th update looks likely to be the cause - too much of a conincidence not to be.
Of course Technical Support won't be open until Monday to report it and I doubt they will fix it before Christmas.
In the words of Victor Meldrew, "I don't believe it!"
The more people who contact Sony and Amazon about this the more likely we are to get the problem fixed.... unless of course that fix introduces another error.
It's a real shame because the 4K panel on my TV is superb - just the operating system and updates that seem to be such a mess.
Anonymous
Not applicable
UHD Issue.
I have logged this issue with Sony.
https://community.sony.co.uk/t5/televisions/2015-android-tv-bugs-and-issues/m-p/2076770#M38116
john.pringle
Same here on Amazon video. Also more even daily blank screen with sound issues There was only the occasional one before December update Now regular Not happy. Sony sort this out please. Sent from my iPad
jain236
i have made my mind.. mine 8405c is going back tomorrow... i am still in 30 day period so hopefully i shouldt have any problems with currys.... shame i really wanted to have sony... but unfortunately..i cannot cope anymore with the issue....
i will wait for sometime and then chose.
