2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
profile.country.GR.title
NPatri
I am having the same issue with the ethernet on my kd55x8509c, but I am not 100% sure if it's related to the firmware. The technician came today to replace the main board but could not boot the TV with the new one. The tv was playing the intro music, like after a factory reset, but there was no picture so he could not load the firmware. He placed the old one back, so the problem with the ethernet remains. Still trying to figure out a solution..! I've waisted another day with this stupid tv.
alanxce
Not sure if it's of any help but I also have the 8509c which I updated the day the latest release came out. I have had no problems with the Ethernet connection before or after the update. In fact, it runs much better than I ever expected given our maximum broadband speed is 16mb/s.
petersincock
Just had a new issue arrise that i havent seen before.
Installed the new update the day it came out. In the last hour the TV (KDL-43W805) has turned itself on and it goes to the bluetooth settings screens. It has done this twice.I havent even been in the room when it has done this.
Has anyone else eperienced this ?
P
NPatri
Thank you for the info, but I am not sure either. It seems that some of these problems are not widely spreaded... But it is very weird for the ethernet to stop working without a reason. Sony's technician verified the problem.
frogger38
New picture quality issue. A really odd one, which I didn't mention before as I thought it a one off. It has now happened twice. It affected two different HDMI inputs and I think the built in receiver. Don't know what provokes it but will be looking out for more indications. I think it is triggered by switching inputs, but it never happened prior to the update. Has anyone else seen this?
Intermittent Picture Quality since update
  • The normal deep blacks are lost, becoming grey, equivalent to raising the black level control by 10 points. The overall look is 'smokey'. This is completely resolved by a 'soft reset' which restores the excellent picture tonal quality.
Product is is Sony 2015 KDL 43W805C Android TV, UK Model with YouView, purchased Sept 2015.
scoopy6
@frogger38  we have the same thing i.e. "....there is a new? Issue, which I though was resolved...
  • Screen flickers off and back on when accessing the TV guide and sometimes when entering HOME screen."
For us this has been the same since we got the tele in July 2015. Since the HDD PAP upgrade it is now every time, instead of most of the time, and whenever the guide is accessed.
It seems to be more than a flicker: the guide screen displays fully, then the screen goes black for a moment, before the guide screen reappears (or, going in the other direction, the TV channel screen).
I think it was once said that Sony 'could not reproduce it' but then a couple of updates ago that it 'had been resolved' . Very strange.
49X8309C in uk
Anonymous
Not applicable
@frogger38 @scoopy6
EPG Flickering upon accessing:
https://community.sony.co.uk/t5/televisions/2015-android-tv-bugs-and-issues/m-p/2040066#M34590
Are you both saying that this problem has returned?
I have just tested this on mine (YouView disabled) and this issue is not present.  I do get a flicker upon exiting the EPG (off-on-off)
scoopy6
@Anonymous on our Tv the on-off-on when accessing the guide did not go away at all (YouView disabled from the start), and currently, upon opening the guide, it is present every time. I did not do a factory reset after every software update but did so after the recent HDD update.
49X8309C in uk
scoopy6
PS we don't have satellite connected, but could it possibly be something to do with there being a pair of terrestrial tuners?
49X8309C in uk
frogger38
@Anonymous @scoopy6
I was watching a Freeview Channel (Youview disabled) on seeing your post pressed GUIDE, guide came up with black background, then snapped off for 1/2 second then came back with the programme playing in the background. It doesn't happen every time but about 1 in 4 times. Not sure how it was before as I was using Youview until I added the HDD. The Youview seemed to behave better.
