2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
r1d2001
@alwhite40 wrote:
@r1d2001 wrote:
I've had this problem previously with my 43W805C and still do on occasion, this seems to stem from it selecting the wrong color temperature. Going into color settings and just selecting the color temperature corrects the issue.
For "curing" the issue, I had some success with a factory reset and then stepping through the set up guide, ensuring I didn't skip any part of it, which I had done when I first got it.
I have the TV permantly set to Cinema Pro with tweaked settings, now when I turn it on I can see that it's on a cooler color temperature setting from the on screen info, then after a pause it selects the correct settings. Every now and then it doesn't and stays on the cooler setting, this usually happens (as near as I can tell) after the TV has been turned off via HDMI CEC because an attached device has gone to sleep. If I turn the set off without using HDMI CEC it usually selects the correct color temperature when I turn it back on, after the aforementioned pause.
My set is connected to devices via a Pioneer SC 2022 receiver conneced to HDMI 4 (ARC). It's definitely a bug as far as I'm concerned.
Thank you for confirming the issue too.
In my case it doesn't seem to be related to HDMI CEC.  It seems to be more to do with the length of time the set has been in standby.  If I switch off for 5 mins or so, then back on again, it will select the correct picture settings fine.  If left overnight, it always fails to select correct settings.
This is always the case, regardless of the last device being used.  It happens if I've been using Sky HD (which doesn't have HDMI CEC sleep link) and it happens with YouView (which obviously doesn't go through HDMI at all).
That's how the problem initially presented itself on my set also, at least that's how it seemed. In fact I initally suspected it was down to the Daydream function.
dazworld
Both the software and hardware are proven to be issues on the sets.
The software is unfortunately poor, and the hardware is not powerful enough to handle the software.
If the software is updated, the set will run even slower. Software companies' first priority is looking at the current, new modes as these are the ones being sold.
2015 Android TV's are already a dog; they'll become more of a dog with Marshmallow.
Risc0n
Contributor
I disagree, the hardware is pretty much ok for what it needs to do. The software is where the issues lie. This TV is night and day differernce from a year ago and the latest update made substantial difference to performance and picture quality. Its the BUGS that are unforgivable. Things such as youtube lipsync, lack of 5.1 sound in amazon prime and random slowdowns of the UI.
profile.country.en_GB.title
petsmart
I would like to report that since the latest update I am experiencing a sound delay on you tube.
Everythig else seems good. Still no 5.1 via plex with the app or casting to the TVs though.
works with an external chromecast with 5.1
55x8509c
Garymjh
TV Sony KD-65X8505C
1) Standard Video Player app does not respect aspect ratio. I use it to play videos via DLNA. Videos are always expanded to use screen area. That results in distorted picture if the video has resoltion of 1980x800. The video player has 2 zoom modes. But I do not see any diffrence. Also zoom button of remote control is not supported (I got on-screen message "function is not supported")."
I've already posted a fix for this, but it's easily lost in the 500+ pages, here it is again:
Press the "Action Menu" button, go to the Video section, select "Information", then press "Back" et voila!
_____________________________________________________________________________________________
I also now can't get the video app to play the correct aspect ratio via dlna. And choosing fit screen or expand makes no difference. (I also don't understand why your tv has a an information option under video as no one else seems to have it)
This problem could be temporarily fixed if Sony simply allowed a manual changing of the video app aspect ratio. I can't understand why it's been disabled. What's the logic there?
Anyway can someone like Quiinicus confirm that thi aspect ratio issue has been reported as a fault and/or if there's any fix in the pipeline? Thanks very much
Kevin8098
You can also hold the power button on the back of the TV, this will force a
reboot.
TWLeebo
@Garymjh I believe I have "Information" beacause I'm playing the files via USB not over a network.
rooobb
I use Video via a network (a serviio DLNA server on iMac) and do not have the "stretching" problem... may you try another time toggling the screen format on the home setting menu and again toggling fit/stretch action when in Video app?
bobm2t
Since the last update I downloaded (weekend 17/04/16), the Internet connection appears to fail. Connects for a split second then the announcement/warning appears 'lost connection'. When I visit the Network options, my network isn't listed. I go into Set up and it appears! I try signing in again, thinking the update wiped the password details. Try it all again and no connection. I am using a 4G EE wireless set up.
The whole thing worked fine before this last update. TV doesn't even appear on the Network settings of my Apple Mac computers anymore...
I wonder if anyone from 'Sony Support' looks at these discusions?
And when can we use the built-in HDD Drive to record from the transmissions? Seems it was released to market before it was fully tested and able to deliver what it says it should be able to do.
A little bit frustrated because if the update was the root cause of the problem I have, I can't update it again...
Cheers,
Bob
Garymjh
No sadly it's been reported many times that toggling between fit and expand
makes no difference. It's a bug,a very simple bug, that Sony don't seem
remotely bothered about.
