2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
Anonymous
Not applicable
@Risc0n - No further updates im afraid 😞  Ive asked !
I do not think there will be any bug fixing in this update tomorrow - I could be wrong, but....  The YouView update is specific to UK Only, many of the reported issues are EU as well.  Its only a guess though.
Risc0n
Contributor
Damn, they sure are dragging their heels on this!
louis8888
Thank you for your response, I did not buy the android tv yet because I saw in the manual (sony support site download) in small character addendum that 4K was not supported over DLNA but only over USB HDD.
This enable me to discover this thread about android that is really frightning !!!
And I got not ANY response to my mail from SONY support !? both on UK site and on French Site.
So I will not buy an Android SONY anyway.
Good luck with firmware updates. I feel sorry for you all.
Best regards
//Edited by Quinnicus to change subject title back to original
Sdroid
What? I have no problem playing 4k over dlna
Anonymous
Not applicable
@louis8888 can you please tell me where you got this information from and ill check into it.  As Sdroid says above, it works for them, so.... Have you actually tried to play a 4K file via a DLNA device?
sassbs
Hi Just saw the update is out, don't have 30 minutes to install it at present. Enjoy Sent from my Windows Phone
louis8888
Hi, Most of PC/MAC/IPhone mediaservers convert video files before sending it to the TV, are you sure that you see 4K on the screen, my experience is that on a SONY 1080p TV, you can see easily a difference between original 1080p capture and 4K capture converted to 1080p, the later is far better, so it is possible that you feel that TV is showing 4K but in fact it is showing the better video 4Kcapture converted to 1080p Thank you anyway best regards From the manual, PC connection, list of supported formats 4K
Ultra HD content is supported as follows: SOURCE PHOTO MOVIE Internet streaming Supported Netflix® Ultra HD 4K , Amazon 4K Ultra HD instant video USB Supported Supported (HEVC) DLNA Supported Not supported HDMI Supported Supported
https://sony-paa-pa-en-web--paa.custhelp.com/app/answers/detail/a_id/85970/~/what-media-player-file-...
Heckie
I've installed YouView - works really well. Massive improvement on functionality with the mini guide.
Still no 5.1 from Google Play Movies, so maybe no bug fixes and still Android 5.1.1.
mk1.golf.1983
Really? I just installed it and now i want to uninstall it. The ui is slow and there is no programme reminder. The Youview android app doesn't work with it either.
Heckie
Mine works well not sluggiush at all, but tbh I've not really had any of the issues reported on here.
