2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
profile.country.IE.title
EggDublin
I've updated everything and youview is installed. Don't have an ariel connection availible but it says on the website that I should still have access to catch-up which is all I want. Have internet but cannot see any way to access catch-up. Can anyone help?
After I switched from PLEX till KODI I've begun to experience lip sync issues and some other issues.
The lip sync is only encountered when watching FRIENDS (stereo track) and mostly when Rachel or Monica talks, seems in sync most of the time when ex. Chandler blobs out with jokes..
Another thing is, SOMETIMES when I play a movie with surround, only static loud noise comes out of my speakers.
I have enabled 5.1 speakers, best match and audio passthrough including DTS and Dolby capable options. Turing it of doesnt help on lip sync, nor does turning hardware acceleration off or on... what the heck do I need to do?
ANDYST3
Re the you view update i have upgraded to the latest software  and because i do not have a tv areial as i have sky via satielite youview will not work!!!! Making it useless for me as cannot access itv player and channel four  on demand yet can use bbc iplayer and demand 5 & would of expected that you could tune the channels via internet as with BT youview boxes and now tv - yes people will say i have all the on demand sevices via sky
very disappionted that you cannot use youview via my BT infinity connection
Heckie
All the catch-up apps should appear under Featured Apps on the Home screen  - I have iPlayer, ITV Player, 4OD and 5 Player - they all work as separate apps without launching YouView.
chelmersteve
I've installed the YouView update and now want to remove it - how can I do this?
The interface is intrusive and generally annoying
mk1.golf.1983
The lack of reminder and programme info and sluggish ui did it for me. I too would like it removed or disabled, keeping the on demand players would be nice though.
ANDYST3
Channel 4  on demand and itv player  yes they are in featured apps but everytime i click on to them to open them it takes me to youview set up section is this a fault then or do i need an areial or do i need to reboot again or go through intial setup
bbc iplayer and demand 5 work no problem
Heckie
You get programme info if you press the relevant button on the remote.
Yeah there should be a reminder function - that is an oversight. This is v1 of the software, so no doubt (ok maybe a few doubts) it will be improved.
danielbeyzade
Which website does it say this on?
EggDublin
@danielbeyzade
Not sure if you are asking me that question but Sony's website says:
Can I use YouView on my Sony TV without an aerial?
Yes, you'll still be able to watch On Demand and use the search features (Internet required). However you will miss out on Live TV. For the best experience, we recommend using both an aerial and an Internet connection.
In my case I think it's a geo locaction issue. I will try a VPN instead of smart dns and report back.
