Hi was just wondering if the A80J will have support for 4k 120hz Dolby Vision in a future software update or if it is a hardware limitation?
It seems that any TV using the mediatek soc cannot manage Dolby vision and 4k@120hz at the same time. So I guess is hw related.
Do you think this will be a concern if I am only using a PS5?
Ps5 does not support Dolby vision at all
