Android 10 update breaking WiFi connections
Daveb124
I have the xh9505 and it recently updated to android 10. Ever since then the WiFi won't connect to my WiFi mesh. And it looks to be related to 802.11r - fast roaming, being enabled on mesh networks. I'm not the only one who has had this issue:
https://support.google.com/androidtv/thread/246199346/tv-cannot-connect-to-wifi-after-android-os-10-...
Unfortunately I don't have the option to disable fast roaming on my network and I don't really want to as it's a standard and very useful feature. Can Sony look to fix this please
4 REPLIES 4
LightFoot
Specialist
Hi @Daveb124   I am sure that they will have a look, but only if you make them aware of the issue. I’m afraid that this is just a community of customers and not Sony customer support. Let them know below.
https://services.sony.co.uk/supportmvc/en/Contact/Email?cat=televisions-projectors1&tab=Tips
Please come back and let the community know, if you get any answers.
Maybe, you can try the connection after a fast roaming disable. Fast roaming can you reactivate later.
Daveb124
My network devices don't support disabling fast roaming unfortunately.
Daveb124
Thanks I'll do that !
