Android TV - WiFi and Ethernet Issues
Anonymous
Not applicable
Hi All
I have noticed that there are some people reporting issues with network connectivity.
Please reply back in this thread with your issue.  Please also list your tv model and all relevent information.
205 REPLIES 205
Mryan84
Any further luck with this?
I installed the TP link plugs but these are a little troublesome as well.
Ran a connection test and only getting 6mbps. Phone on WiFi is pulling in 26mbps.
Would really just prefer my TVs WiFi worked as it's meant too.
Engineers came out and fitted a new main board which didn't work, they then took it away and worked on it at the workshops on return it worked but I have to do a soft reset on most days, if that keeps working I'll live with it.
profile.country.IE.title
06d61967
Very hard to connect to wifi. Have to go through set up sequence every time and then it still won't connect or find router. Maybe get connected one in ten attempts
I have very slow wifi and LAN speeds on my XBR-55x850c tv.    I get 300 megabites on my computer and phones with high speed Xfinity.  I only get 10-20 megabites on my TV eityher thru LAN or wifi.  Are some settingsa wrong?
rooobb
Have you read all the thread? How did you measure the network speed on your tv?
danis72
Hello. The model of my tv is KD49XF8096. I have serious problem with wifi connection . Many times on starting the wifi the internal software switch of wifi turn to off on its own, after that is not regognize any local network,  i turn it on manually and after that on its own again turns of. The authorized technician coming to my home and puts the latest version of firmware, the problem not solved. After that tecnician takes the tv and telling me that replaces all the internal electric hardwares  boards for wifi, after that the problem stll remains.
After that i replace the channels of my router. the problem is still there
Other devices (tablets, mobile phones) doesnt have similar problem with the wifi network on my home
The device is repairing only with factory resets, but after that not periodically the problem show up again
I bought the tv before 8 months and i have the problem 6 months ago. i believe that sony must replace my tv, what is your opinion
Thank you
nwa3000mp3
I have the same problem with my 65 inch Sony android TV, Sony don't seem to be interested, looking at the forum this issues has been around for years, Sony seem to be incapable of providing a fix.
My fix will be
1. Never but another Sony TV!
2. Buy a Fire stick and use that for smart services
Both of the above are not ideal but I'd bet that hell will freeze over before Sony provide you with a new TV!!
Will_cain
I'm not sure who you contacted to get the repair done but it's worth looking at this article
https://www.which.co.uk/consumer-rights/advice/how-to-get-a-faulty-product-replaced-or-repaired
ancaise
KD-55XF9005 V8.0.0 V66520 kernel: 3.10.79
Since V6.6520  ( PKG6.6520.0252EUA )  software update we cannot connect TV to the internet. It connects to the LAN but without internet access.
WIRED was working perfectly and allowed software upgrade!
https://community.sony.co.uk/t5/android-tv/sony-bravia-tv-no-internet-access-since-v8-0-0-v6-6520-ke...
ancaise
further to previous rply
All devices in the rest of the house are functioning correctly
- network status, everything looks good and picking up DHCP correctly
connection methind: wired
cable connection: ok
Ip address setting: Auto
ip address: 192.168.8..205
subnet mask 255.255.255.0
default gateway: 192.168.8.123
primary dns: 81.139.57.100
secondry dns: 81.139.56.100
MAC: 70:26:05:B6:E2:AB
Proxy server: Not used
SAME FOR WIFI DHCP AS WELL
Connection Results
cable connection: OK
Local access: OK
Internet access: Failed
- i Can ping tv from laptop, so connected
- there are no sat or cable connections just HDMI from SKY and CAT5 from LAN
- tried a different cat5 cable
- different LAN port
- tried SKY box and Laptop in LAN port, both work
- checked date and time on TV and router
- recycled power via taking plug out of TV and router in between each stage / change
- tried DHCP & Fixed IP
- tried different router (current is Draytex) but tried BT Home Hub
-EDIT 01/08/19 - tried to connect to iphone hot spot - connects then just reboots and will loop until you quickly go in and turn off wifi or stop hotspot!!!
- EDIT 05/08/19 - tried setting primary DNS to the same as the router / gateway - local access then failed as well as internet
- data and storage factory reset
- tried firmware on USB but said its all up to date
- batteries out of remote and pressed button for 10 seconds
- stopped the SAMBA service
- EDIT 01/08/19 - As per Robs suggestion we had already tried fixed ip with google servers
ROUTER LOG, so its trying to connect
Private IP :Port #Pseudo Port Peer IP :Port Interface
192.168.8.205 55835 49307 10.10.10.10 443 WAN1
192.168.8.205 56402 49874 10.10.10.10 123 WAN1
192.168.8.205 60136 53608 216.58.206.100 80 WAN1 GOOGLE
192.168.8.205 52030 45502 172.217.169.67 80 WAN1 GOOGLE
Andy
