BBC iPlayer not loading
Benny23
Hi, BBC iPlayer, ITVX and several other apps have stopped loading on my Sony Bravia Android TV.  Netflix, Amazon Prime, YouTube and others work.  I have performed a factory reset but this hasn’t fixed the issue.  Please let know how to resolve this.
Benny23
Hi @LightFoot I’ve just fixed it by uninstalling an update.  Thanks for the quick reply though.
7 REPLIES 7
LightFoot
Specialist
Hi @Benny23   Sorry, we cannot help you without the full model number of your TV. It will start with KD, XR or K.
Benny23
Bernard-orange
Hi, @Benny23 please can you tell me how you did this? We are having the same issue. Thank you!
langdaler
i have same problem..it has always worked but yesterday stopped functioning..how did you solve it?
it will not open on tv with remote control press but i can cast it from android phone no problem.
i cannot find a way of updating the app on my Bravia 75WL 50 inch tv
Bernard-orange
Hi @langdaler @I did this in the end and it worked!
langdaler
Spoiler
thank you so much for that reply,appreciated..... i couldn't understand why it stopped working as i have used it regularly until problem yesterday,i had tried everything!
anyway-have followed instruction and it now works successfully.🙂
Bernard-orange
@langdaler @Great!!
Yeah it randomly happened to us and we tried everything. Sony wasn’t very responsive on replies so I had to do my own research. Seems like a failed update at their end. Annoying!
