BBC iPlayer UHD
Damohtc
Entdecker
BBC iPlayer UHD
I have recently purchased as Sony 65XH90(UK) and non of the UHD content will play via iPlayer including the rest loop, all other content is fine. This is 2nd panel I’ve had with the same problem , my LG tv plays iPlayer UHD content fine so it’s definitely the Sony TV
27 ANTWORTEN 27
standinman
Entdecker
The firmware is pkg6.7140.0358EUA
standinman
Entdecker
It's the latest firmware making the android version9
kdhuk66
Mitglied
Latest Android 9 firmware version on XH85 is v. 6.4960.
https://www.sony.co.uk/electronics/support/lcd-tvs-android-xh85xx_x85xxh_xh91xx-series/kd-43xh8505/d...
H series TVs were built with Android 9 from the start
standinman
Entdecker
I'm not sure if this helps but ,i manually installed the latest firmware ,from sony support using a usb drive,maybe there's a pending update for your firmware maybe on sony support,my update dated oct2020 .
I've had my set since march
2020,
and my only gripe is processor power !
kdhuk66
Mitglied
It's very recent... 26th November 2020.
My TV installed it itself on the day after it was released.
I can't be completely sure but I don't think UHD streams on iPlayer worked on the previous firmware either
My installed software details are PKG6.4960.0628EUA . (This was always going to be diferent to any software on an XG series TV....?)
standinman
Entdecker
Yes I'm sure your right,Let's hope they sort out the iplayer issue,it's funny though the some people with xg80 range of tv's seem to have the same issue,as you ?
Mitglied
Hi. My firmware is the same as yours.
my UHD worked fine before this download on the 26th. Both BBC and Sony are working on it hopefully.
kdhuk66
Mitglied
@08081979
What model is your TV?
kdhuk66
Mitglied
Ah! Ok... You're the Sony KD-48A9 guy?
So a 2020 model? Makes sense....
Mitglied
Yep that’s the one!
