pickard11
Bluetooth help.
I own a KD-65X900C and for as long as i have had it i have had trouble keeping Bluetooth turned off. For some strange reason it turns itself back on again within an hour or so of being turned off. Can anybody help as i would like to turn it off until needed.
I do have the latest update installed as of 02/01/2017.
Thanks.
Anonymous
Not applicable
Hi there
This is a known bug/issue that has unfortunately not been resolved yet.  See:
https://community.sony.co.uk/t5/android-tv/android-tv-bugs-and-issues/m-p/2193783#M85
2 REPLIES 2
Anonymous
Not applicable
Hi there
pickard11
Thanks for the info.
Hopefully this will be resolved soon.
