Can you sideload apps on the Bravia android sets?
SpookyZeus
Can you install apps that are not suppose to be on the TV. For example my Phone has Sky go on it and would be interested to see if i can get it going on the TV.
1 REPLY 1
You can try... From PC's Google Play or directly from APK (Android Installation packaging).
After that, you can see these App in another App, SideLoad Launcher (install also...).
But remeber, the "others Apps" aren't optimized for Android TV...
