Checking resolution when using apps
mobilyuk
Hi all
When using YouTube or Netflix how do you check the resolution i.e. 1080i/p/2160p of what is playing? When selecting action menu the info button is not there. Is there any other way?
2 REPLIES 2
IamNic
Hello @mobilyuk,
in YouTube you have an option in the apps settings to activate "Statistics for nerds" which will show you that info.
- Nic
adamski99_uk
To check the resolution on Netflix press the information key (I+). It displays the bandwidth and resolution being used.
