Difference between 43XE7003BU and 43XE7002BU??
CaptainLambino
Hi all,
I have been looking at these two models
43XE7003BU and 42XE7002BU
I cant see to see any difference online apart from the price (about 40 quid)
I will be mainly using the TV for ps4 pro and Netflix etc
Melinda
royabrown
Enthusiast
The 7003. I looked up all the required information here.
YouView Superuser, but not an employee of YouView, nor retained by them for this purpose. It's purely me speaking
3 REPLIES 3
royabrown
Enthusiast
100 Hz versus 200 Hz Motionflow.
200 Hz (if you can see the difference from 100 Hz) should theoretically be better and snappier for sport, gaming, etc.
There’s a 7073 with 400 Hz. Should theoretically be better still.
CaptainLambino
Hi - thank you for your reply. I’m confused - which one has the higher HZ?
thanks
royabrown
Enthusiast
