- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
FREESAT SET UP HELP NEEDED
i have sony bravia tv and i have a wideband lnb how do i set up freesat?
I have 1 Sky q box and 1 mini box
thanks
Arthurx1234
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @arthurx1234
The starting point for any request for help is the full model number of your TV. It will start with KD- or XR-.
Unless you specifically specified that you wanted to keep an existing FreeSat setup when you ordered Sky Q then it will impossible to add normal FreeSat as you needed a Hybrid LNB. Wideband LNBs only work with the new 4K FreeSat boxes and don’t work on most TVs including Sony.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
thanks
The model number is XR 65A84K
Arthurx1234
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @arthurx1234
Thanks for that. So you cannot set up FreeSat on your TV with a standard wideband LNB. If you have a look at the LNB connections at your dish you should see that all the ports are in use. If you do have a Hybrid LNB then need a satellite installer to add and feed the cables to your TV. You could enquire about them installing a Hybrid LNB if you don’t have one.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for the info, will get a price from a local installer as i think sky would possibly overcharge
arthurx1234
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@arthurx1234 wrote:Thanks for the info, will get a price from a local installer as i think sky would possibly overcharge
Hi @arthurx1234 Sky would not be interested. They only fit a Hybrid LNB if ordered in advance and the cabling is already in place. They have zero interest in FreeSat.
