Google accounts at startup on x95k
lloydmelsomesmith
Is it possible to keep your google accounts but stop the tv asking which one to use at startup. Ie, just start and go to terrestrial Freeview.
4 REPLIES 4
LightFoot
Specialist
Hi @lloydmelsomesmith
I have never seen a Google account choice on startup, but then again I only have one account. If you have more than one account, try reducing it to one.
What have you set your Power-on behaviour setting to? If set to Last used input, and TV was the last then it should startup on the last channel viewed.
Press the Quick settings button (a cog) and try changing the Power-on behaviour. You may have to choose Edit (far right) to add it to the choices first.
lloydmelsomesmith
Thanks, I’ll try that tomorrow, also, I’m having trouble enabling Sony mode instead of youview for the tv planner/guide.
LightFoot
Specialist
Settings -> Channels & Inputs -> TV button shortcut-> Digital -> Select your default TV app for Digital -> TV (not Live TV & Catch Up).
lloydmelsomesmith
Thanks for your help.
