Comparte tu experiencia!
Hi is there a way to change the order of theses inputs or delete some ?? Plz thanks
¡Resuelto! Ir a solución.
If you go to the last row, you should found the setting option and there you can for sure set which rows to show and (but I don't remember) you should be able also to change the view order.
That’s it , many thanks
