- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
KD-65A1 Subwoofer output issue
Hello,
I love great picture and I'm not fan of great home theater multichannel sound. However I missed a little low frequencies. When I discover on my TV the option Subwoofer under Headphone/Audio out, I become very happy. I run to my near electronic shop to get an active subwoofer. You can imagine my disappointment when I discover that the option subwoofer separate NOTHING! All frequencies are passed to the woofer. Even on 5.1 tests on YouTube I hear all channels from sub and nothing when LFE!!! Wonderful! Now I have a sub I can not use Smiley Sad
Hope I missing something and you can tell me...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Nic,
Thank you for riching out.
I connect my subwoofer to headphones (with a stereo headset adpting to LFE's mono RCA) and set the headphones as subwoofer on Audio settings.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @ArianHD,
since you mentioned in your first post, that the setting is called Headphone/Audio out, the TV may also have a stereo chinch output somewhere on the back.
- Nic
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
"Stereo chinch"? Not familiar with this term. Help pls
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The red and white plugs (connectors are colored as well).
Presumably your headphone (TRS) cable has these connectors on the other end as well.
- Nic
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@IamNic wrote:The red and white plugs (connectors are colored as well).
- Nic
Yes. It's exacly like that. Standard stereo jack to RCA https://goo.gl/HFf6Hu then RCA stereo to RCA mono https://goo.gl/kcv3Fp
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @ArianHD,
what does the input on your subwoofer look like?
Is it orange? (since you go back from stereo to mono it is probably a coaxial port - a port which has nothing to do with Chinch and requires a different signal type)
- Nic
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @ArianHD,
then it is even a dedicated subwoofer input.
While the plug fits I am quite certain, that a direct input that way wouldn't work.
At least I have never seen a setup like this without a receiver in between the TV and the woofer.
Have you looked for a Chinch output somewhere else on the TV?
- Nic
