KDL-43W805C - Google Play Store Empty?
pantalej
Hello all,
I have a problem with the Google Play Store. When I open the application its Home screen flickers with what is supposed to be shown, you know... apps and such, and then it goes empty - there is nothing shown. As seen here: undefined
Anyone have the same problem? Or better yet a solution?
57 REPLIES 57
casper501
firmware = PKG2.647.0052EUB
google app store  = 6.0.2-leanback
Dione7624
firmware: PKG3.155
app store version: 6.0.2-leanback
pantalej
Sony supoort has send me an email with workarounds, that I will try as soon as I get back home.
JFYI:
- Workaround 1: Go to “Home” - Settings - Network - Remote start - Switch to Off - Unplug and re-plug TV power cord. Did this Workaround help to resolve the issue ?
- Workaround 2: Go to “Home” - Settings - System Preferences Date & Time - Automatic Date & time - Switch to Off - Unplug and re-plug TV power cord. Did this Workaround help to resolve the issue ?
profile.country.RO.title
alexw85
Nothing
pantalej
Neither of the provided two workarounds had any effect on the Google Play Store application for me as well.
alinux33
It looks that 6.0.2 leanback its the latest PlayStore version for Android TV, but if you guys think that might worth trying to downgrade to previous version 5.10.31, see how it goes and try to upgrade to 6.0.2 again.
Here you can get the apk's for PlayStore for android tv:
http://goo.gl/9znaja
undefined
alexw85
you cannot downgrade. It's from the app itself because before the update it was ok with the 5.10.31 leanback
alinux33
Just saw there is a new firmware update v3.179 as of today 02.02.2016 for W8c and W7c models.
I am currious if this will fix the PlayStore empty issue.
Anonymous
Not applicable
Please confirm if the new fw resolves the problem.  It is 'hoped' that it will, but unfortunately this problem cannot be replicated in testing.  So fingers crossed
alexw85
Worked after the update. After the first restart asked for licence agreement again and now it's back like it used to BE. Google store empty
