KDL42W653A apps issue
msansom123
I know this is an old problem (for me and on here!) but I have tried every solution posted here and elsewhere to try to access the apps through this TV. Nothing works!
Is there a possible hardware problem?
Other Samusung TVs connected perfectly via wifi!
Any advice different to all the other posts on here!
Thanks
2 REPLIES 2
LightFoot
Specialist
Hi @msansom123. You may be better off asking your question in the https://community.sony.co.uk/t5/other-tvs/bd-p/tv_en_1  forum. As far as I can see the KDL-42W653A is not an Android TV.
msansom123
Thank you
