Hi, I have a Sony Bravia 8 II. Since the latest update, I’ve been having an issue with the Last used input option. When I turn on the TV, it always switches to HDMI 3 or HDMI 4, even though I turned the TV off while watching regular TV, not using an HDMI input. I tried changing the option to Google Home. When I turned the TV off, waited a minute, and turned it back on, it correctly showed Google Home. However, when I select Last used input, it doesn’t restore the actual last input I was using. Instead, it switches to an HDMI input.
Is anyone else experiencing this issue? I’ve tried almost everything, and a factory reset is my last resort.
I also have a Bravia 8 and having problems with HDMI ports
