Monitor - Can One Be Connected Too KD-55XH8196
KyaMarley75
Hi is It Possible to Connect A Monitor To A Sony Bravia X81h.
The Screen Is Cracked And Cant Find Anyone To Replace The Screen.
I Have A Replacement TV Through Insurance But Seems A Waiste That My Damaged KD-55XH8196 Is Unusable. Any Information Or Help Appreciated.
Thanks.
SkyNet404
Specialist
Hey there,
Why don't you try to replace the whole set from a Sony service centre? Though it won't be cheap I'm afraid.
Cheers.
4 REPLIES 4
SkyNet404
Specialist
Hey there,
Cheers.
KyaMarley75
Sony Centre Said They Couldn't Replace The Screen Would Be Cheaper To Buy A New TV Which My Insurance Covered If TV Couldn't Be Fixed. Just Seems A. Do Sony Not Reuse The Spare Parts?
SkyNet404
Specialist
Yea that might be cheaper actually. I think they realized that only replacing screens would be a hassle or would cost more, so they were like. Why bother? Anyway, hopefully you get the TV replaced by the insurance soon buddy, cheers.
KyaMarley75
TV Has Already Been Replaced 😁
I've Still Got The Damaged TV Don't Know What I'm Ment To Do With It, Sony Came Out Inspected It & Write It Off As A Bad Job Lol. Seems A Waiste Just To Take It To The Local Tip. Don't Know How China Haven't Jumped On Replacement Screens For Smart Teleys 🙈😂😂. It'll Just Hav To Gather Even More Dust Then.
