Navigating Programme Guide
GillyBrown2
Hi, just bought a Bravia Android TV, and so far loving it, but find the manual a bit lacking in detail. Can someone help me with what might be a basic question.
Across the top of the Guide is a Series of buttons: ‘Tool’ and then what look to be a bunch of useful filters, one of which is HD (which is what I was hoping to use). My question is what button (or combination of buttons) do you use to navigate up to that bar?
thanks!
Tags (2)
GillyBrown2
Answered this myself now. It is the red coloured button. When viewing the guide, there is a key at the bottom, but even on our big new TV the text is quite small.
1 REPLY 1
GillyBrown2
