MrBombastic21
Neftlix info button
Up until now I could use the "i" (info) button on my TV remote and I'd see the resolution of the Netflix stream 4K, HD etc.
It seems this is not possible anymore. Pressing the "i" button has no effect. Is it something caused by the last Sony update or is it a Netflix thing? (the interface has changed a bit).
Anonymous
Not applicable
Hello All
According to some posts from forum members today:
https://community.sony.co.uk/t5/android-tv/netflix-info-button-now-working/m-p/2302797
https://community.sony.co.uk/t5/android-tv/info-button-stopped-working-on-netflix-65x8509c/m-p/23023...
This issue appears to have been resolved.  Now closing this thread
24 REPLIES 24
Anonymous
Not applicable
Hi there
I have the KD-55XD8577 and I can confirm that the info button does indeed work with Netflix.  Try a reboot of the TV by pressing and holding the power button on the remote control for about 6 seconds - the TV should then reboot itself.
MrBombastic21
No changes after a reboot.
As I said, the Netflix interface seems also a bit changed when watching.
If I pause I get three icons on the top left, while it was different until now.
My model is 49X8005C and both the TV and the app are up to date.
It's not a huge problem, but I'm used to check the info when watching 4K just to be sure.
I would just like to confirm I'm not the only one experiencing this.
kdombaz
my TV no longer has this feature either. Shame it was handy.
Anonymous
Not applicable
Hi there
I can ALSO now confirm that the Info no longer works for me, looks like Netflix have made some app changes. Im going to see if I can find out more about this.
Anonymous
Not applicable
Hi All
Just done a live chat with Netflix about this.
undefined
kdombaz
@Anonymous Thanks for this.
HowlinWolf_PL
waiting for the fix then...
HowlinWolf_PL
undefined
That what i was told today...so we might need to wait for any info on Sony side as well...
Anonymous
Not applicable
Hi there
Just after I contacted Netflix the other day, I also reported this problem to Sony.  Sony are aware of the problem anyhow.
