Netflix app crashes
kevin.robertson24
Netflix app crashes
My Netflix app crashes whilst watching programmes on my new Sony a90j. I'm trying to attempt a factory reset but can't find the option.
I can't see it in settings, home or anywhere.
Any ideas?
Thanks
6 REPLIES 6
Joe_Dohn
Specialist
What's the full model number you have? Also, are you on the latest software version (v6.3628)?
kevin.robertson24
Thanks for any help you can give.
Model no
  • XR-65A90J
Software version PKG6.3640.0455EUA
I also find the picture is not as clear as my 9 yr old Sony Bravia which was replaced with this one costing 3.5k, supposed to be Sony's best and clearest TV ever.
It's as if the ariel signal isn't strong enough but have the same ariel and booster as before.
Joe_Dohn
Specialist
Have you tried clearing the cached data (under Device Preferences - Storage - Internal Shared Storage - Cached data) then restart by holding power?
kevin.robertson24
Hi, yes tried that thanks. Netflix support has advised I contact Sony Support so I'm trying to build my energy to make the call!
kevin.robertson24
Sony accessed my TV and performed a factory reset which has solved the Netflix issue.
I still don't know how to do it myself from the tv settings as Sony didn't even know!
Apparently the method has changed for this new model and they aren't aware of how I would do it.
Not good really is it! Anyway thanks for the help.
Joe_Dohn
Specialist
Glad to hear the issue was resolved for you!
It'd be really helpful to others if you mark your last post as the solution ^^
- JD
