Делитесь своим опытом!
Invested in KD-55X9305C Great telly but not included in NowTV compatibility This and similar models are top of the range products. Why not include? I recognise NowTV probably determined cut off but the app is compatible with Android 8.0 and above Can Sony not upgrade from 7.0 to 8.0 to facilitate access to NowTV app? Really annoying...
It was a great TV indeed but it is 5 years old, you have to adapt to it. Maybe Android 8 will be ported, but there is no guarantee, IMHO you should better go with a nowtv stick or other compliant device
£25 for a NowTV Stick, with a one-month Cinema Pass thrown in, off Amazon?
Hey, don’t sweat it.....
